Quck Quadzilla question....need answer fast!
Old Nov 18, 2007 | 12:34 PM
LT250rich's Avatar
Default Quck Quadzilla question....need answer fast!
So my buddy just bought a sweet *** '87 zilla and there is a little window above the trans but below the head. Now should that window have oil in it or is it just for condensation?
Old Nov 19, 2007 | 11:31 PM
Airbrushhead's Avatar
The only window I know on the quadzilla is the power valve window. It is right in front of the jug. There should be no oil in there. To check the oil, you have to take a bolt out by the water pump and see if oil trickles out.
Old Nov 20, 2007 | 10:49 AM
LT250rich's Avatar
yeah thats it. What is the purpose of the power valve window?
Old Nov 21, 2007 | 12:25 AM
Well.If you look elsewhere in this forum, you'll see I have asked the same ? with regards on how to set it. No response, so I played around with it. If you look on the opposite side of window. you'll see a "****" to turn. 0 thru 500 on newer zillas. 0 thru 250 on your buddies.If you take the two screws out and plate off, you can remove **** and see that there is a spring that creates tension on power valve. 0 alows valve to open up quickly while 500(250) alows opening up later in higher RPM's' You can see this happening in window. Still messing with it thru trial and error.
Hope this helps.
Old Nov 26, 2007 | 02:29 AM
fosgate's Avatar
Go to this web site! Your log-on info from this site will work the same on the LT site! http://s15.invisionfree.com/LT...00HQ/index.php?act=idx
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
