Kingquad 700 track systems
Old Nov 25, 2007 | 02:08 PM
KQ_dagen's Avatar
Default Kingquad 700 track systems
Does anybody have experience with these or any other track systems on the Kingquad 700?
CAT TRAXX
Old Nov 25, 2007 | 05:34 PM
BradW's Avatar
I'll admit that those ATVs with tracks are cool. But for 3,000+ dollars, you could buy a really nice snowmobile that will go better in the snow, and 3 times as fast. If I had more money than I knew what to do with, I'd definitely have a set, but if money is a factor, I don't see how they can come close to the performance of a snowmobile. If you're gonna use them in the mud or something, that's a totally different story. But make sure they are "all surface" because some of the track systems are only for use in the snow.
Old Nov 26, 2007 | 12:08 PM
deanz400's Avatar
I've seen video of a tracked ATV going thru snow where a sled got buried ,there made for slower going where speed isn't a huge factor better floatation .and fewer lbs psi
Old Nov 27, 2007 | 02:26 AM
CaptainQuint's Avatar
I've seen a tracked ATV go through some insane mud. You couldn't take a wheeled ATV through it...heck you couldn't walk through it. The tracked ATV just idled right through. Really something to see. I was determined to have some until i saw the price. ouch.
Old Nov 27, 2007 | 09:32 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: CaptainQuint
I've seen a tracked ATV go through some insane mud. You couldn't take a wheeled ATV through it...heck you couldn't walk through it. The tracked ATV just idled right through. Really something to see. I was determined to have some until i saw the price. ouch.</end quote></div>
Problem with that is once your through that insane mud section your stuck with these tracks that slow you down by 90%
for the rest of the days ride.
Hit a 2 mile logging road section and it will take you until Thursday to complete it. Your riding buddies will be sending a search party out because they are wondering whats taking you so long.
Old Nov 27, 2007 | 10:25 AM
deanz400's Avatar
TLC from what I've found out about track systems there are some that don't change your gear ratios and some the most sever you can loose 20% off your top speed ,most arer 10 to 15% gear reduction .and most track systems would only be used when you know your going to be in some extreme conditions ,where you'd be pulling your buddies out of a nasty mud hole ,
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
