QuadRunner LT160
Old Dec 3, 2007 | 06:07 PM
jazzjunky's Avatar
Default QuadRunner LT160
Hi All,
I bought a used suzuki LT160 in a messy condition and discovered that it wont shift, neutral lamp always on. I suspect that the foot pedal linkage ***** are worn because the shaft turns very little even when I pull up the pedal almost ninty degrees up. I elongated the rocker arm and changed the angle of the spline female but nothing works. can loose ***** lead to such a problem?
Old Dec 5, 2007 | 04:27 PM
mjlar94's Avatar
if its anything like the 230's its the gearing on the clutch cover side, make sure you line it up and push it towards the shifter side before puting the cover on.
If the kick start is like the 230 (if it is) the toothless sides face directly up on the cover and case.
Dammar
Apr 20, 2016 06:03 AM
phummer3210
Sep 11, 2015 03:47 PM
Sep 1, 2015 11:59 PM
Bergmann
Aug 13, 2015 03:51 PM
bikedad3
Jul 2, 2015 02:15 AM
