Dial a jet?
Old Dec 19, 2007 | 09:44 PM
mikem92's Avatar
Default Dial a jet?
Has anyone tried dial a jet? If so, how was the installation? does it work right? I want to buy a k&n air filter for my 230 (i have uni now) and i also have my air box lid drilled out but i might fill those in if i get the k&n. I just don't want to go through the hassle of taking the carb apart over and over again to get the right jetting. I know next to nothing about the fine tuning ideas of jets. I think this would be good for me but im not too sure. I think it might be a hassle itself and i have been leaning towards no. If anyone could help me out, i would appreciate it.
Also im looking for somewhere to get lt250r front wheel spacers (around 1.5") for a pretty good price.
Thanks in advance
Also, a new pipe may be in my future so that's why, theoretically, I would think dial a jet sounds right for me.
Old Dec 20, 2007 | 12:22 PM
LT80's Avatar
LT80 Expert
Default Dial a jet?
I've been told the dial-a-jet is a great thing.
Get a outerwears for the K&N.
Old Dec 21, 2007 | 02:54 AM
JustRandy's Avatar
Default Dial a jet?
PoolGod used to have a dial a jet on his 230 before it was stolen. I remember his signature used to say he highly recommended it. .... I'm about to give it a shot myself just because of temp changes and I ride in the mountains sometimes.
Take your airbox lid off and throw it in the garbage.... You'll never need it again. Get the KN filter. Then get the dial a jet and it should be lean enough already so you wont have to install smaller jets. All you'd have to do is install the dial a jet.
Old Dec 21, 2007 | 11:52 AM
PoolGod230's Avatar
Default Dial a jet?
Yep they are very cool! Got one for the 260cc I am procrastinating, I mean building. Easy to install, easy to adjust. Get the outerwears for the K & N, won't affect air flow, but will keep water and fine dust out of your engine with the box lid removed. Oh, be sure you get the snorkle for the dial a jet.
Old Dec 21, 2007 | 01:20 PM
mikem92's Avatar
Default Dial a jet?
Thanks a lot guys!
It sounds like i got me a dial a jet coming in eventually. Along with a k&n with an outerwear. You guys sure ill be fine with the lid off with an outerwear? Often times i am in mud and water so that is the thing that worries me. Although, if i take the drain plugs out also, then any water that gets in will instantly drain out.
anyways, thanks :]
Old Dec 21, 2007 | 01:31 PM
PoolGod230's Avatar
Default Dial a jet?
I blast through probably 10-12 inches of water regularly, quite a bit of mud as well, just clean up good after the dirty rides, and life is good!
Old Dec 21, 2007 | 05:45 PM
mikem92's Avatar
Default Dial a jet?
haha okay that sounds good to me. Thanks a lot
STLyamwar
Jul 25, 2020 04:44 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Mphillips
Jun 26, 2015 03:52 PM
coolhuh
Jun 24, 2002 04:05 PM
sparkys
Jan 30, 2002 10:31 AM
