Help! Quadzilla
Old Feb 24, 2008 | 10:39 PM
3&4wheelerdude888's Avatar
Default Help! Quadzilla
I just bought a 1985 Suzuki Quadzilla. It is bored some and when I go to kick it over, the clutch sticks sometimes and it jumps foreward and drives a little when you give it gas. Do I need a new clutch cable or a whole new clutch altogether. It comes out of sticking if you jar it forward when its turned on but it's slightly annoying. I would like to know what the problem is because i am going to fix everything up on it that is wrong. Please help, Thanks Guys!
Old Feb 24, 2008 | 11:43 PM
QWODER's Avatar
Quadzillas were not made in 85.Are you starting it in gear with the clutch lever pulled in?If its pulling a little while clutch lever is pulled in then it may just need some adjusting.You can adjust it at the clutch handle and at the other end of the clutch cable where the clutch shaft goes into the motor.Try the handle first.
Old Feb 25, 2008 | 12:04 AM
Alright, I'll try that. Thanks, I'll get back to u probably tomorrow. (2/25/08)
Old Feb 25, 2008 | 10:56 PM
Well, there was no daylight left when i got home today so i will try it tomorrow. Sorry.
Old Mar 3, 2008 | 02:33 PM
ZillaRider87's Avatar
are you sure its a quadzilla? they didnt make them in 85, it coulod be a suzuki 250r though.
Old Mar 3, 2008 | 05:01 PM
CTATV's Avatar
yeah got any pics of it? and its harder to start in gear should start in nutral. one of my dirtbikes gets a little sticky if I havent ridden in a while when i put it into gear with clutch in it pops forward a foot or so but after that works just fine and only does it if it hasnt been run in a few weeks
Ashley S
Feb 18, 2024 08:56 PM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ashley S
Aug 6, 2015 12:56 PM
FENDERBENDER
Mar 12, 2000 01:04 PM
