install winch 07 eiger
Old Mar 7, 2008 | 09:17 AM
carym1967's Avatar
Default install winch 07 eiger
I am installing a winch on my 07 eiger that is pre-wired. Can someone tell me if I still need to use the solenoid that came with the winch? without taking all of the plastics off the quad, i cant follow the wires that are supposed to connect to the winch--also, they are yellow and blue....not sure which is hot and which is ground
Old Mar 7, 2008 | 10:33 AM
OIown12's Avatar
I installed a winch on my pre-wired Polaris. It was very easy. I did take the front plastic off to access everything better. You will need A solenoid. Mine was supplied in the kit. I mounted it in it's pre-drilled location, mounted the winch and hooked up the wires as described in the wiring diagram. My Polaris had the switched hot wire connection under the headlight pod and the battery cables just below that. Entire install took about 1.5 hours with the bulk of that being getting the plastic on and off.
Good Luck!!
Old Mar 7, 2008 | 10:48 AM
carym1967's Avatar
I guess the problem is with the battery cables....by instructions tell me to go from the battery to the solenoid and from the solenoid to the winch.....I am not sure exactly where the "prewired" wires would come into play
Old Mar 7, 2008 | 11:09 AM
OIown12's Avatar
You should have pre-wired battery leads that are, in some way, already connected to the battery. These connect to the solenoid. Use the short wires that came with the winch to connect the sloenoid to the winch. Switched power should also be available up front (mine was a red wire with a female end). Also, if you have a handlebar switch, it just plugs into the solenoid also.
Old Mar 7, 2008 | 11:13 AM
carym1967's Avatar
yea......that makes sense.......thanks for the info!
Ill give it a shot
Old Mar 7, 2008 | 01:44 PM
eigernthemud's Avatar
the prewired wires go from the front where the winch mounts at and run along the frame all the way to the back and come out above the storage box in the rear im not sure if that helps or not but thats where a few of my buddies have mounted their contactor
Old Mar 8, 2008 | 03:26 PM
scrappiedew1's Avatar
i have a 2005 eiger the solenoid that came with the winch will have to be used use the short wires to go back to the battey you will find the pre wire for the wicnch up under the seat in the back in the middle of the atv i think they are zip tied.i uaed dielectric grease on my contacts. up under the front handle bars were the speedo is there is a orange wire and i think a extra grond this wire wire provide the power for the winch i hooked it direct because it is switch you have to hold down for the one i have i know for sure the wire is orange . if you need any more info just send a reply back and i can go out and look at mine .
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
