question about lt250r frame
Old Jan 18, 2001 | 11:44 PM
rooster06's Avatar
I have an 86 lt250r that im in the middle of ripping down. The frame was once cracked where the shocks bolt onto the frame at,(the usual place). My question is, what is a good way to reinforce that area so it wont likely crack again? And is there any other places on these frames that should be rinforced so they dont crack. Any info would be helpfule. Thanks
Old Jan 19, 2001 | 02:05 AM
dual-sporter's Avatar
one of my buddies had angle iron welded on the top of the frame above the shock mounts, the tube being inside the V of the angle iron... he ran it above & below the mount a couple inches, plus re-welded the tubes.
there also a number of spots the factory reinforced in the front section of the frame in later years... i'll look at them & get back to ya.
Old Jan 19, 2001 | 06:45 PM
rbowman's Avatar
Mine cracked on the left side down tube, right where the footpeg bolts to the frame. I haven't found any new signs of cracking, but it doesn't hurt to check after a ride.
Old Jan 19, 2001 | 10:11 PM
badchad's Avatar
I used 1/4" flatbar and cut it out to fit underneath the front shock mounts centered on the frame and welded it in place and that solved the problem. I also welded a peice of angle iron underneath the footpegg to keep them from bending down and cracking the frame in that area. Hope you get yours fixed up. It's actually pretty easy to do.
Old Jan 20, 2001 | 01:58 AM
where the factory added additional gussets in '91-'92 in the front:
-on top of the tube at the shock mount, in front & rear of it.
-in front of & behind the verticle tube at the back of the A-arms, to the bottom frame tube.
-on top & bottom of the upper A-arm mount tube at the point it attaches to the previous verticle tube.
i assume they added gussets to these areas for a reason.... but then again, i could be wrong.
they are small enough that the pipe can clear on the left side.
i don't know for sure if they reinforced the footpeg area at all, haven't had time to caompare w/ my friends' in that area. i would assume they changed it some since they did make significant changes to the rear suspension in '91.
Old Jan 21, 2001 | 04:02 AM
85lt250's Avatar
I have an 85 250 and it cracked on the right side behind the footpeg. I had it welded and it broke about 8 months later. It is in a tight spot and I have not come up with a way to strengthen it yet.
Valder
Nov 28, 2020 07:38 AM
cornermike
Sep 10, 2015 08:30 AM
John Reed
Sep 9, 2015 03:46 AM
Rooky
Sep 9, 2015 03:16 AM
bmark0610
Sep 7, 2015 09:42 PM
