87 QuadSport Question
Old Apr 22, 2008 | 12:06 AM
NeXuS21's Avatar
Default 87 QuadSport Question
I bought this 87 Quadsport from a kid down the street i looked at the oil level indicator and i didnt see anything i thought it was low but i dont think it was now that i think about it ..so i added a little over a quart started it up and it started smoking.. Didnt smoke before i added the oil...I drained it all fearing i overfilled it put in about 2 quarts still smokes i didnt think running it for about 3 mins with to much oil in it would cause it to burn up a ring or somthing.. i drained all the oil out again and added 2 quarts agian still smokes changed the plug still smokes i can see oil at the tip of the exhaust pipe so its spitting it out but like i said would 3mins with to much oil burn up the ring? any help would be Appreciated.. P.S. It didnt smoke untill i added the extra oil..
Old Apr 22, 2008 | 01:38 AM
tydogg's Avatar
Did you make sure you put in the right classification of oil. I would refer to the manual and make sure, just a thought. I did that in a ride on mower once, didn't pay attention and it smoked alot untill i put in the right oil, let us know.
Old Apr 22, 2008 | 12:54 PM
NeXuS21's Avatar
yea im pretty sure I was sure it was a 4 stroke so i put in a 10-w40 after i put it in and started it i relialized that i over filled it like i said ran for about 3 mins then drained and put in a motorcycle 4 stroke 10w40 2 quarts of it still smoked then i drained that out and put in 1 and 1/2 quarts 10-40 and 1/2 quart of ring treatment still smokes like a Train
Old Apr 22, 2008 | 05:58 PM
JustRandy's Avatar
Just ride it. It has oil all inside the exhaust pipe now because you over filled it. Either that or you was wrong about it not smoking before. It will take a long time to get all the oil out of the pipe. I used to ride the **** out of mine and then when it was good n hot I would hit it again with a torch till it stopped smoking. It took a LONG time to get it all out.
Oh, and about the oil. You need oil for OLD engines (1988 and earlier). Type SG I think. SL is no good for your clutches and it will make them slip a little. Walmart has Accell brand oil that says pre-1988 right on the bottle.
Old Apr 22, 2008 | 06:08 PM
NeXuS21's Avatar
hey thanks yeah ive been riding it for about 30 mins now but still smokes i thought about cleaning out the exhasut pipe thinking it was built up inside there.. I will get some of that oil today and change it out. i noticed i little slipagge when i put this new oil in.
Old Apr 22, 2008 | 06:40 PM
JustRandy's Avatar
Take the drain plugs out of the muffler too. It may even run better when you do. Mine did. So, I drilled 3 or 4 more holes.
Old Apr 25, 2008 | 01:42 PM
NeXuS21's Avatar
i looked around but didnt see a bolt to take out Is there a chance mine doesnt have it and if not could i just drill some holes and where is the best spot to drill them at?
Old Apr 25, 2008 | 02:18 PM
JustRandy's Avatar
Is the muffler stock? The stock one should have them. After market... who knows.
Old Apr 25, 2008 | 02:21 PM
NeXuS21's Avatar
i think so... its black looks stock to me looks really old so im guessing yeah still stock
Old Apr 25, 2008 | 02:25 PM
JustRandy's Avatar
Go here http://www.alpha-sports.com/suzuki_atv_parts.htm
Click on 1987, then on 230s, then click on muffler. #13 n #16 are drain bolts.
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
shimanok2
Jan 29, 2016 07:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
