front disk brakes
Old May 13, 2008 | 06:12 PM
bernardo's Avatar
Default front disk brakes
New member, new atv owner, used 2003 Suzuki Ozark
Previous owner wore pads down to metal, the disc/rotor is smooth on one side and rougher on the other side. I was in the process of putting new pads on but now hesitate to finish job. How long will the pad on the rough side last before it needs to be replaced? I hate to put them in, wear them out quickly, the have to put new rotors in anyway. Can the rotors be repair like the old rotors in cars? Also, one caliper is sticking, and has some wear from the rotor.
This atv will not be riden much, and will be driven in normal conditions.
Thanks
Old May 13, 2008 | 06:33 PM
SuziOzark's Avatar
Hello. I also own an Ozark and have researched just about everying about them. Personally, I would go an buy a new rotor because it is not good to have one pad wear out faster than the other. This will certainly effect braking and in the long run, it will come down to the same amount of money anyway. If you have to keep buying new pads, that money adds up. And with that money, you could have bought a new rotor and your pads would last longer. Not sure if you understand what I'm saying but I hope you do. Bottom line, I'd buy a new rotor but that's your decision if you want to replace a rotor or not.
Good luck, be safe, and have fun!
2008 Green Suzuki Ozark
Completely stock but hopefully new tires
in the near future. (Interco Swamp Lites
or GBC Gators)
Old May 13, 2008 | 06:37 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums bernardo.
It's not the pads wearing out you should worry about. It's the rotor. When it's gone, so are the brakes. Like SuziOzark said, replace the rotor. A lot cheaper to replace that than all the parts that will break when you use an inanimate object to stop.
Old May 13, 2008 | 08:44 PM
bernardo's Avatar
Where is a good place(internet) to get parts? Rotors are around $100 at the local Suzuki store in Raleigh, NC.
Old May 28, 2008 | 04:05 PM
RonV's Avatar
A year ago, I replaced the pads on the front of my Eiger and noted that the rotors were rough. Well, the pads are completely worn down now and this time, I'll be replacing the rotors. The pads I used were EBC severe duty pads, so I expected them to last a bit longer. I firmly believe the bad rotors significantly contributed to the excessive wear of the pads. I quoted Eiger rotors from Prosourceoutlet.com for about $27 per side. I can't imagine the Ozarks are much more than that.
Old May 28, 2008 | 04:16 PM
RonV's Avatar
WOW. I just looked up the price on those rotors and mrcycles.com had them for around $75/side. Those suckers are pricey.
Old May 28, 2008 | 05:48 PM
Williebee's Avatar
I would also reccmend that you replace the rotor's at the same time as the pad's , the new pad's will last longer and the brake's will work better ; you will save money in the long run by replacing the rotor's now !
Check ebay you might luckup and find a new pair of rotor's that someone bought for their quad and desided to trade or buy a new quad and still have the rotor's , i found a new pair of backing plate assemblies/complete with new wheel cylinders , shoes and spring's the whole work's already assembled for my old 86' Honda TRX350 Foreman 4x4 ; and they where less than the cost the Dealer wanted for just the cylinder's and shoe's alone !
But whatever you do i would replace the rotor's before putting the pad's on the quad , like everyone else has stated ; you will come out better replacing them the same time as you replace the pad's !.......
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
carolinabomb
Jul 26, 2015 08:40 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
