2007 kingquad temp. light
Old May 27, 2008 | 04:48 PM
gatortown's Avatar
Default 2007 kingquad temp. light
Can anyone tell me why the temp. light on my kingquad just comes on for no reason. The fan works and its not hot.
Old May 27, 2008 | 05:16 PM
immerume2's Avatar
You are likely going to need to post more information in order to get a decent answer. When does the light come on? When you first turn the key... When you start the quad... After riding it for some time? I assume that all fluids have been checked? Has this been a problem since you first got this quad? Was it brand new when you got it?
Old May 27, 2008 | 05:30 PM
gatortown's Avatar
I purchased this quad used and it had this problem then.The light comes on when you turn the key.All the fluids are ok.YOu can get it to go out if you turn the key on and of a couple of times. Seems like to me a sensor is bad ,dont seem to affect how it runs.
Old May 28, 2008 | 08:30 PM
cluby's Avatar
The hot light I beleive is also the FI light as well. Go in an get it checked for any codes. Also unplug the ecm and see if the pins and connector are caroded.
Old May 29, 2008 | 12:29 AM
gatortown's Avatar
now that i think about it ,it does have F1 in there too.thanks for your help ,i will check that out next time i am home
Old May 29, 2008 | 11:28 PM
ALB12's Avatar
I've been having the temp light issue since about Feb (on my 07 700 too).
During a few winter rides, it went on after I hit some water. I thought the steam may have triggered the sensor but wasn't sure. The dealer couldn't duplicate it.
I rode 50 + miles this past Saturday and had no problems (even after getting winched out of a deep puddle / mud). Then after cleaning the machine and double checking the radiator was clear I rode on Monday (about 25 miles) and had to stop 4 or 5 times to let the fan run and cool down til the light went off. It was a harder ride on Monday. More slow technical trails and I think that may have had something to do with it.
It's been hard to pinpoint but at least I have more data to give the dealer this time around. It's going in on Saturday. I'll post back if they find something.
Also, since the ignition recall, my battery has been draining and needed to be jumped 3 times in the last 2 weeks to start it.
Old Jun 2, 2008 | 12:49 AM
gatortown's Avatar
ok,this one dont seem to have anything to do with the temp.one day it does good,the next cant get it to stay off.I have sprayed out the radiator,still the same. I think its what the other feller was talking bout.I am going to check the ecm connection when i am home.Another thing that makes me beleive that is it usually runs fine with the light on,the fan will kick on and off like it should.But every now and then it wont even start till u screw with the key,and get the light to go off.I even disconnected the battery one time to get it to go off.Any how i will figure it out sooner or later.By the way ,does Alb mean albuquerque by any chance,if so i am bout an hour west of there.
Old Jun 2, 2008 | 12:51 PM
cluby's Avatar
You should just take it in to your dealer, if your out of warrenty ask them how long your emmisions warrenty
ylomnstr
Sep 22, 2015 12:19 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
ylomnstr
Sep 4, 2015 05:02 PM
