'85-'86 lT250R VS. '87-'91
Old Jan 24, 2001 | 12:31 AM
hondaaatv's Avatar
I'd like to know what the +/- between the differant models. This would greatly be appreciated.
Old Jan 25, 2001 | 05:49 PM
URnotRoscoe's Avatar
85/86 +cheaper to buy than a 87-92
-less aftermarket parts available
-less hop ups available (bigbore kits etc)
- the swing arm WILL break if it hasn't already problably will break the casesaver out of the engine case when it does
- no powervalve
87-92 + all the - of the 85/86 are gone, - you will spend more for one on the initial investment.
Goodluck
Old Jan 25, 2001 | 10:23 PM
rooster06's Avatar
The main difference between the 85/86 and the 87 and later models is the later models have a powervalve. Which makes them faster. And the frame is a little more reinforced. But as far as the 85/86 having less aftermarket parts available for them, I would have to disagree.
Old Jan 26, 2001 | 02:38 AM
rockrider's Avatar
One of the things I liked about the '85-'85 model was that the dry weight was 293lbs! The later models were around 325lbs and used a complicated chain adjustment system. The later models had the power valved MX style motor equipped with a 6 speed tranny. The front shock angle was changed on the later models as well. My brother has a cherry '92 model and it is way fun to ride. It will be interesting to see how Suzuki's new sport quad stacks up against the older ones.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
LTqracer
Sport Quads
19
Jun 2, 2004 07:20 PM
donpeter
Apr 4, 2001 12:31 AM
Steve10
Aug 2, 2000 03:32 PM
