What does PRI mean? lt50 for fuel shutoff?
Old Sep 28, 2008 | 10:55 PM
alwaysready's Avatar
Default What does PRI mean? lt50 for fuel shutoff?
ok the guy said to turn the **** on the left side to pri in the back to turn off the gas.
it says
PRI ....................PRI (towards back)
.............. ON
Why is there 2 pri's
what does PRI mean
Anyone have a copy of the users manual [img]i/expressions/face-icon-small-happy.gif[/img]
Fax, email, or, snail mail (With reimbursement) would be great
Or ill have to order one from suzuki Fun
Old Sep 28, 2008 | 11:13 PM
OLDSCHOOLQUAD's Avatar
There is no real "off" on your petcock. PRI means prime, this means that the fuel line by-passes the fuel pump/filter and goes directly into the carb (usually gravity fed). I only know this because it is the same on my old kq. I only have one PRI though, you have two? Can't help you on why there might be two. No manual, just thought I would chime in. I just leave my fuel petcock on all the time. Unless you see a spot underneath your quad, this should be fine for you as well.
Old Sep 28, 2008 | 11:21 PM
ya it was dripping some gas in the back of my Jeep (cherokee) o the way home ill have to keep an eye on it.
there wasnt any gas on the floor at the guys garage that i noticed.
ya 2 pri's on if you point the arrow forward one if you point it towards the back [img]i/expressions/face-icon-small-happy.gif[/img]
So when should i use the pri? ever?
or after the winter since i usually run it out of gas for storage?
thakns for the info
Chris
Old Sep 29, 2008 | 12:58 AM
AFRAID2FLY's Avatar
The only time you will need the PRIME is if you run completely out of gas or if you drain the carb for service/cleaning.
Old Sep 29, 2008 | 11:39 AM
thanks for clearing that up for me.
Do i need special oil for the oil injection?
the guy said he used regular 2 stroke oil, but i thouhgt i remember reading someone saying using injection oil.
is there a difference...
(Places where tha manual would come in handy [img]i/expressions/face-icon-small-smile.gif[/img] )
Old Sep 29, 2008 | 12:12 PM
Did you say in the Cheorokee!!LOL!! That is hardcore. Bet that is fun getting in and out. I can't say I have ever seen that before. I would definately use injection oil, although you probably would be fine with the regular 2 stroke oil (but I would use the best in this case). Good luck.
Old Sep 29, 2008 | 01:55 PM
Ya i have a 2000 jeep cherokee that is lifted 3.5" with 31's, offroad bumper w/ winch, rock rails etc on it.
flipped down the back seat it fit perfect..
I did measure that it would fit before i went to get it too [img]i/expressions/face-icon-small-smile.gif[/img]
Pic with just the lift and tires
ETA Rode it around the yard today to check it out ran great for my little newbies..
only got alittle wet since its a rain day here. oh well have to go hide it till christmas now [img]i/expressions/face-icon-small-happy.gif[/img]
Later guys
Old Sep 30, 2008 | 06:54 PM
WAATV's Avatar
The two PRIme settings are identical. They gravity-feed fuel directly into the carb. I use them for first-of-the-day cold starts:
1) Push choke lever down.
2) Turn petcock to PRI.
3) Pull starter cord.
4) When engine starts, turn petcock to ON.
5) Run for 15-30 seconds, then lift choke lever.
Works great every time.
When not using the machine, leave the petcock in the ON position.
Old Sep 30, 2008 | 09:57 PM
thakns for the input.
I did leave it at the on posiiton when i parked it in the barn.
found a users manual on ebay. 29.00 plus 6 for shipping LOL
ill wait longer or ill figure this stuff out one at a time..
Later guys [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 14, 2008 | 02:24 PM
tnginfla's Avatar
When the pitcock valve is on ON, should any fuel come out of the picock valve? I only see fuel out when in the PRI position. Does the diaphram in the pitcock valve serve as like a fuel pump? I'm having trouble getting an 85 LT50 to start after fuel system rebuild. Compression and fire are good. Sparkplug gets wet. I assume the fuel line for PRI goes to the carb and and the other one goes to the manifold? Any info on carb air/fuel adjustments? I am two turns out on fuel and a 1/2 turn out on air (guess). Any help would be appriciated.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
