1993 quad king
hey there got a question hope someone knows the answer too. Have a 1993 quad king 300, the carb is flooding. It is clean, has a new needle valve float is set right choke works fine, the needle position is in the factory setting, the air fuel is set at 2 1/2 turns from stock. any idea why its doin this? thanks jake
Check to make sure that your fuel valve is not set on prime (PRI). Most Suzuki's don't have an off position on their fuel valves, just a run, prime and reserve setting. Also, it's King Quad, not Quad King.
Jaybee
Jaybee
That's what I was talking about, yes. Double check that valve - It's been a few years since I had a KQ, but like I said above - Most Susuki ATV's don't have an 'OFF' position. If it's left in the PRI setting it can flood.
Other than that it just about has to be in the carb, even though it sounds like you've got everything covered there.
Jaybee
Jaybee
Do you have a fuel tank vent hose coming off of your fuel cap? Sometimes, if it gets clogged either at the cap or in the hose then with weather change (just like gas in a plastic container) it expands and causes too much pressure sending gas right through the filter and pump into the carb. Funny though, I have to flood mine to start, quite the opposite problem I guess. Good luck!!
I got a question for anyone who can help. I just got a 1994 king quad LT-F4WD yesterday and I have to hold my hand over the intake on the carburetor to make it idle. What could cause that? I also have another question I have 2 lines that come off the carburetor and go up near the neck of the fuel tank. One is broke off and the other looks like it was on something. What could those be for?
Carb vents....
Frisky2050
Apr 9, 2020 11:19 AM
