Eiger Grip Warmer Install
Old Oct 19, 2008 | 10:35 PM
acevedor2's Avatar
Default Eiger Grip Warmer Install
Hello everyone, I just found this forum and it seems to have a wealth of information. I am trying to install some grip warmers for my Eiger 400. So far I have installed the grips onto the ATV and I have installed the switch to the handlebars. Now I am into the harder part which is running the electrical connections. My question is - where do I connect the hot wire? It should be to a switched connection, where do I find one? Is there a way to run it to the fuse box? I have not taken any of the panels off yet, but I imagine I will have to in order to route and zip tie the wiring.
Any suggestions for me? Should be a fairly simple install, with only two wires to connect, butI just don't know where to connect them to. Also, any "gotchas" I should be aware ofwhen removing the panels around the gas tank, etc. Thanks in advance for any help.
Cheers.
Old Oct 20, 2008 | 08:04 PM
BradW's Avatar
I tied mine into the 12-volt outlet.
Old Oct 20, 2008 | 08:10 PM
TLC's Avatar
TLC
Outlet is a good place. anywhere power is shut down if key is "Off". Don,t want your battery run dead because you forgot the turn the warmer switch to "Off" when you park it for the night.
Old Oct 21, 2008 | 10:09 PM
acevedor2's Avatar
Thanks guys! Great tip. That's exactly where I tied it into and they work great! I certainly appreciate all of the help!
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
black_thunder
Sep 7, 2015 01:24 AM
toonces
Sep 5, 2015 01:14 PM
