04 Vinson
im not really sure, but i was looking im my book and it doesnt give any details it just says remove this remove that... but if i had to guess i from looking at the pics in the book you have to remove the side cover off the and theres a nut that holds the bracket for the throttle cable and ideal screw. remove that nut and you should beable to remove the bracket and then the cables should come off... if its the choke cable that you want off then the easiest way i have found to get them off is to remove the carb and unscrew the choke cable by just spining the carb ( its easier to unscrew the carb from the cable then the other way around), once the treads are all the way out all you should have to do is just pull it out. that how i have done it on other wheelers, i have never had my vinsons carb off so im not 100% sure... but any other machine thats how i have done it... i hope some of this might help... good luck buddy
btw its spelled KEIHIN
