First Maintenance on 2007 Eiger
Old Oct 21, 2008 | 10:12 PM
acevedor2's Avatar
Default First Maintenance on 2007 Eiger
My Eiger is Brand New. Actually, I have had it for about 6 months, but I was deployed right after I got it, so it has been sitting for the last 5 months. It has about 2-3 hours on it right now. I am getting ready for hunting season and am looking to get it serviced (service it) to make sure it is good to go.
What is recommended. Yes, I read the manual, but I am looking for some advice based on experience. It starts and runs good as it is supposed to. It might just be me as this is the first quad I have owned, but it seems a little noisy - almost like a Singer sewing machine sometimes. Rat tat tat. I am probably exaggerating the noisiness, but Is that normal?
Thanks again!
Old Oct 22, 2008 | 01:14 AM
atvman29's Avatar
Where does the sound seem to be coming from? Where was the ATV stored? Maybe the belt could have gotten a little stiff and is thudding a little bit from sitting idle so long.
Old Oct 22, 2008 | 01:18 AM
acevedor2's Avatar
Pretty sure the engine is the source of the noise. Quad was stored inside my garage. Sounds a little tinny - almost like a ticking.
Old Oct 22, 2008 | 01:29 AM
atvman29's Avatar
hmm did you check the oil? How cold is it right now where you live? Sometimes when i start our Ozark in the winter (I'm in Minnesota) it will make some funny noises until it warms up. Is the sound loud compared to the sound of the motor?
Old Oct 22, 2008 | 09:08 PM
BradW's Avatar
The most important thing to do is to change the oil and check the valve clearance at 100-150 miles, and follow the break-in procedure. My Eiger seems to have a tick to it like you describe too. I thought it was the valves but I have checked and adjusted the valves 3 times and the noise remains, and it has not lost power and runs excellent. So, I'm not really concerned.
Old Oct 23, 2008 | 12:38 AM
acevedor2's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: BradW
The most important thing to do is to change the oil and check the valve clearance at 100-150 miles, and follow the break-in procedure. My Eiger seems to have a tick to it like you describe too. I thought it was the valves but I have checked and adjusted the valves 3 times and the noise remains, and it has not lost power and runs excellent. So, I'm not really concerned.</end quote></div>
Thanks! That's exactly the kind of sound I am talking about. Glad to know it is fairly normal. Regarding the valve checking, is there a procedure for that? Is there a link to a how to. I am pretty mechanically inclined, but have never worked on a cycle motor, only cars. Thanks again!
Old Oct 24, 2008 | 09:08 AM
Eiger06's Avatar
Is the ticking from running too lean? or does it sound soft like a spark plug firing?
I had a similar type tick (noticable loud) with my Eiger until I rejetted it. I opened up the pilot screw to richen up that mixture during idle and 1/4 throttle and I also had to jump the main jet up to 132 to keep it from running too lean during runs. I'm in Cincinnati, so elevation wasn't an issue...just too lean from the factory (d*mn emission regulations!). Only ticking I hear now is soft and I attribute to the spark plug firing.
Old Oct 24, 2008 | 09:52 PM
acevedor2's Avatar
Doesn't seem to be running lean at all. Starts, runs, and idles just fine. Actually it seems to be more noticeable after it warms up and not so much when it is cold.
Old Nov 2, 2008 | 06:53 PM
BradW's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: acevedor2
Doesn't seem to be running lean at all. Starts, runs, and idles just fine. Actually it seems to be more noticeable after it warms up and not so much when it is cold.</end quote></div>
x2. As far as adjusting the valves. Tear off the side plastic and pull the fuel tank. Turn the motor to TDC on the compression stroke (there is a threaded plug on the left side of the motor that will let you see when you are at TDC via a mark on the fly-wheel). pull the valve covers and use a feeler gauge to check the clearances. The exhaust valves are a little tricky to get to, but it's pretty simple overall.
dannytas
Sep 26, 2017 06:31 PM
Alex G.
Sep 11, 2017 11:38 PM
cboler9
Sep 24, 2015 08:35 PM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
