lt250r no start after build
Old Nov 10, 2008 | 12:18 PM
carsoncustoms's Avatar
Default lt250r no start after build
great news! what name brand of 2cycle oil you burning?
Old Nov 10, 2008 | 02:12 PM
taylorteamracing's Avatar
well im using a smokeless oil hmmm and i used to use the penzoil but here is something i drained the oil out of the case and only about 1/2 of a quart came out i put about 1/4 of a quart in and fired it up (dangerous) but it smoked very little so i shut it down this brings me to believe the cas or cases have a issue i replaced both crank seals and bearing and used moto seal to seal the cases im going to check the crankcase vent later today when i get out of the dreaded work place
Old Nov 10, 2008 | 05:08 PM
saywheresarny's Avatar
there is also a seal in the bushing that goes on the clutch side of the crank. its a little o-ring that slips inside bushing. and the bushing goes with the tapered side out. might want to check on that before you split the cases. best bet would be to do a leakdown test. hope you get it all worked out.
Old Nov 11, 2008 | 12:13 AM
hmmm now that i think of it i did replace that oring and seal but i think i put it in with the teper pointing inwards not out
Old Nov 11, 2008 | 07:03 PM
  #15
<div class="FTQUOTE"><begin quote>Originally posted by: taylorteamracing
hmmm now that i think of it i did replace that oring and seal but i think i put it in with the teper pointing inwards not out</end quote></div>
im not sure if that would make it leak but its worth checking into. better than spliting the cases if you dont have to.
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
scaldwellk
Jun 19, 2015 05:08 PM
1000gade
May 27, 2015 12:37 PM
owen87
May 9, 2001 05:49 PM
chrisjack
Aug 21, 1999 04:52 PM
