HELP!blown lt250r..rebuild or dump?
Old Nov 5, 2008 | 11:26 PM
jorge_smg's Avatar
Default HELP!blown lt250r..rebuild or dump?
ive had my lt250r for about a year. piston broke in the cylinder and broken pieces all in transmission. not sure if i should rebuild, look for new/used engine or sell the bike. brand new plastics and seat.
Old Nov 6, 2008 | 08:32 AM
Crzy4wlvs's Avatar
I would try looking on craigslist for a used lt250 then use it for parts then do a rebuild... It all depends on how much time your looking to spend on it.. It also depends on how much cash your willing to fork out for the quad... Good luck
Old Nov 9, 2008 | 07:06 PM
saywheresarny's Avatar
lt250r is a 2stroke wich means that under the crank is just part of the combustion chamber not the transmission. so if you didnt mess up the cylinder just get the pieces out of the crank case and put in a new piston. should be an easy fix unless you broke the cases. look in the crank case with a light and see if its broke under the crank.
Old Nov 10, 2008 | 09:41 AM
LT80's Avatar
LT80 Expert
What he said. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 10, 2008 | 12:14 PM
carsoncustoms's Avatar
if any piece of the rings scored up the walls you need to,dependeing how deep,you need to hone the cylinder out.
Old Nov 10, 2008 | 10:38 PM
jorge_smg's Avatar
its a 87....rest of the bike is good brand new plastics and seat im not too sure i want to spend any money on it...does anyone know how much it would be worth?
Old Nov 10, 2008 | 11:34 PM
lucasislight's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: saywheresarny
lt250r is a 2stroke wich means that under the crank is just part of the combustion chamber not the transmission. so if you didnt mess up the cylinder just get the pieces out of the crank case and put in a new piston. should be an easy fix unless you broke the cases. look in the crank case with a light and see if its broke under the crank.</end quote></div>
You should not give advice if you have no idea what you are talking about, which it sounds like you do not. This is NOT an easy fix!
If it were me, and I know that there are pieces in the bottom end, I would split the cases because that is the only way to get any and all pieces out. It is not a job for a novice.
I hate to say it, but it sounds like you should consider finding a motor, or parting out what is left of the bike and put those funds towards something else.
Old Nov 11, 2008 | 12:01 AM
jorge_smg's Avatar
thats what im leaning twards....thanks
Old Nov 11, 2008 | 10:35 AM
LT80's Avatar
LT80 Expert
I agree with Lucasislight as far as splitting the cases being for expierienced mechanics but that's about it.
You should be able to get 99.9% of the broke pieces out of the bottom end. Like saywheresarny mentioned, pieces can get wedged under the crank and crack the cases.
I consider all that and the top end easy.
Head nuts (6), cylinder nuts (4), remove exhaust, remove carb and your in.
You can get another motor that will need as much as this one.
Fix this one and you know what you have.
Piston 150+ or so
bore 40 or so
Gaskets 20 or so.
A cpl hundred bucks in parts.
Old Nov 13, 2008 | 04:59 PM
91Warrior357's Avatar
just use a little magnet to pick up the crap in the crankcase, but if i were you id sell your lt250 and buy a 250r....hahahahah lol
