HELP!blown lt250r..rebuild or dump?
Old Nov 13, 2008 | 09:02 PM
vdubspeed's Avatar
Default HELP!blown lt250r..rebuild or dump?
lucaslight - carefull bro...you sound like you might not have any 2 stroke experience. A 2 stroke has a much different design than a four stroke. Gas/oil go UNDER the piston first and then into the combustion chamber. Under the piston that area is sealed from the transmission and such. A 4 stroke has everything open down there.
For what it's worth, my Yamaha waverunner (old big two stroke) did the SAME thing. Without any knowledge to how motors work, I took the cylinder off, had it bored .030 over, cleaned out the bottom end with a magnet with the engine still in the waverunner, reassembled and it worked perfectly.
Don't be so quick to judge others and their knowledge.
Old Nov 14, 2008 | 04:14 PM
LT80's Avatar
LT80 Expert
<div class="FTQUOTE"><begin quote>Originally posted by: 91Warrior357
just use a little magnet to pick up the crap in the crankcase, but if i were you id sell your lt250 and buy a 250r....hahahahah lol</end quote></div>
LOL LOL you recommend a 250R, he has a LT250R. Oh,,you meant a Honda (which is normally a good idea) but you have a warrior! And even worse, you wasted good money on aftermarket parts for it. His blown up Zuki can be pushed faster than your warrior can go running.How about you stepping it up dude?!.
Ok, ya know that's a joke,, right? LMAO [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
By the way, I'll sell you my mighty TRX 250R. Only ridden by a frail lil girl to 2 (of the 11) national championships and a old fat man in the 40+ class. [img]i/expressions/face-icon-small-smile.gif[/img]
Now if all you would explain how you pick aluminum parts out of a bottom end (or anywhere) with a magnet I'll be one informed fat man.
I use my scribe with the bend on the end. [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Nov 15, 2008 | 12:41 PM
carsoncustoms's Avatar
I used a shop vac to clean mine out in my old honda 250r.what i did was taped a small hose to the vac hose poured gas into the crank compartment suck it out,repeated the process 6 times then put it back together.Never had a problem with it.
Old Nov 15, 2008 | 05:10 PM
LT80's Avatar
LT80 Expert
oops
Old Nov 16, 2008 | 01:46 AM
  #15
the_journalist's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: carsoncustoms
I used a shop vac to clean mine out in my old honda 250r.what i did was taped a small hose to the vac hose poured gas into the crank compartment suck it out,repeated the process 6 times then put it back together.Never had a problem with it.</end quote></div>
You're lucky to be alive. You used a shop vac to vaccum up gas!?!?!?! NEVER use an electric shop vac to pick up gasoline. The motor in a shop vac pretty much always has an electrical arc inside. A little of that gas vapor reaches that arc and BOOM!!!
Old Nov 17, 2008 | 12:54 PM
  #16
I know very lucky infact.I did'nt realize it till I was turning the thing off.To see that it sent a shiver down my spin.
Old Nov 23, 2008 | 02:51 AM
  #17
Simsie147's Avatar
I say dump it and step up to a fuel injected four stroke
Old Nov 23, 2008 | 10:39 AM
  #18
LT80's Avatar
LT80 Expert
Maybe you can lend him the 6-7k needed too. [img]i/expressions/face-icon-small-tongue.gif[/img]
BTW Simsie, you have a yosh slip on, a yosh cherry bomb,,,How ya end up with a FMF mega crap header? [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
fd24
Jan 16, 2019 08:59 AM
kodiacrunner
Oct 4, 2015 11:52 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
