Installing winch on a Vinson
Old Nov 11, 2008 | 10:50 PM
louisiana.brandon's Avatar
Default Installing winch on a Vinson
I am installing a 2500lb Gorilla winch on my Vinson and it has a small power on the cord with the rocker switch that they say to connect to a power cord that gets power when the key is on. I have all the other power cords connected. Is that small power necessary? If so, where could I attach it?
Thanks,
Old Nov 11, 2008 | 11:16 PM
GrnXnham's Avatar
When I installed the winch on my Ozark, I just used "guess-and-check" to find a hot power cable that turned on when the key was on. I found a wad of extra wires hanging down around the steering stem and I took turns sticking the power cable from the winch into each of them while turning the quad on and off until I found one that only worked with the quad turned on.
It's best to only run a winch with the quad running so this power cable is a good thing to install. If you run your winch with the quad shut off, it will kill your battery very quickly.
Old Nov 12, 2008 | 02:21 PM
vinny04's Avatar
remove the headlight cover pull the headlight lens assebly out and you will find several pigtails 3 i think. The orange is hot with the key on. Also under the front fender high on the frame left side as you sit are 2 pigtails orange is hot the other ground (i'm going to use these 2 to connect a horn)
Old Nov 12, 2008 | 03:06 PM
Thanks guys, now I can finish this up this evening! I may finally pull the carb off too and give it a thorough cleaning...
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
