2006 eiger 400 4x4 need help!
Old Nov 27, 2008 | 09:50 PM
grizzly4x4660guy's Avatar
Default 2006 eiger 400 4x4 need help!
i have an 06 eiger that has been awsome. it has been rolled over 7 times. never a prob. i went to go ride it the other day and it started right up. but as soon as u give it more than 1/8 throttle it cuts out. im not sure if its timing or what. i know its not the plug ive changed it. help if u can give me some suggestions before i take it to the bike shop which is wayyy to over priced
Old Nov 27, 2008 | 10:40 PM
cherokee99's Avatar
clean the jets in the bottom of the carb. then take off the top of the carb, be careful ther is a spring! make sure the diaphram that moves the slide up/down is not torn or degraded. also make sure the needle and the slide can move freely inside the carb when its put back together
carb is a good place to start
Old Dec 13, 2008 | 06:04 PM
SKingQuad400's Avatar
I cleaned my carb and changed the plug on mine it was having the same problem took it to the dealer they put a hotter plug in an its running great plug# CR7E try that.
ltrmc02
Aug 22, 2021 02:34 PM
akguy31
Aug 31, 2019 04:34 AM
clscott84
Sep 21, 2015 10:16 AM
snowolson
Aug 31, 2015 03:51 PM
baysport
Jul 23, 2015 11:37 AM
