Suzuki Ozark - What Year/Manual/Oil?
Old Dec 7, 2008 | 09:13 AM
surferjoe's Avatar
Default Suzuki Ozark - What Year/Manual/Oil?
First time poster in need of help?
1) I've got a used Suzuki Ozark 250 (5-speed/2WD) and have no idea what year it is...can't find any model/serialplate..where are they typically located?
2) I'm really confusd about engine oil....what should I use? Are there other engine fluids?
3) I'd like to change the oil myself (and any other fluids) but don't have a manual. Is there anyone who could help me out? I can't afford a service manual so am hopnig someone my have a .pdf for an Ozark.
Thank you very much to all in advance of any suggestions/help.
Old Dec 8, 2008 | 11:14 PM
Ol' QS230's Avatar
alright...
Your Ozark cant be older than an 02 I'm almsot 100% postive they havent made any major changes since then
10w-40 is what I use and it takes 2.3 quarts of that or 2200ml, there are no other engine fluids
The oil is easy, if you look under you'll see the hole cut out of teh kid plate to access the drain plug. Pull the plug, drain, put the plug back in. You'll want to change the oil filter too, thats located on the same side as the fill hole. It has 3 bolts holding the cover on, remove those and simply swap the the new one in. Then fill her up with some frsh oil.
You may also want to change the air filter, or atleast check the condition of it, thats under the seat.
I could take pictures to show where things are, but i wont have it at my house till after next weekend (its on a friends farm).
Hope I helped ya out
Old Dec 11, 2008 | 12:43 AM
Eiger06's Avatar
If you can locate the VIN number...usually stamped on the front vertical frame near the front left tire...you can go to this website and get all the info on your bike.
http://www.motoverse.com/vinDecoding.asp
Go to the Suzuki Cycles under Motorcycles
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
that1redhead
Sep 8, 2015 11:47 AM
Sep 1, 2015 11:59 PM
