z400
Old Jan 20, 2009 | 08:03 PM
teven's Avatar
Default z400
My 04 z400 needs new o rings in the water pump, you have to take the oil cover off to get to them, do i need to buy a new gasket for the oil cover, or can you use the old one, or is there even one in there?
Old Jan 21, 2009 | 01:40 PM
ss97's Avatar
Lets Ride!
Default z400
You mean the clutch cover? And as a rule you NEVER reuse any gasket at all...... doing so only invites trouble. Gaskets are made to be used only once.
Old Jan 21, 2009 | 08:39 PM
cataway's Avatar
Default z400
O-rings ?? if the water pump is leaking its not likely a o-ring more likely the mechanical seal is worn out .
there is a wright up on it ,but i get the fealing it may be a little over you head ,that is if you have never worked on a water pump.
Old Jan 21, 2009 | 09:10 PM
teven's Avatar
Default z400
were is the write up? i looked for it but could not find it.
Old Jan 21, 2009 | 10:19 PM
cataway's Avatar
Default z400
http://suzuki.theatvchannel.co...ex.php?showtopic=38524
Old Jan 21, 2009 | 10:24 PM
cataway's Avatar
Default z400
sorry ,thats the best i can do,other than that get a manual
Old Jan 21, 2009 | 10:47 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default z400
I'm guessing you aren't working on it this late.
When I get back to my other work computer tomorrow, I'll see if I can hook up the link to the service manual.
From that, you'll be able to download the whole thing to your computer.
Old Jan 22, 2009 | 01:47 PM
Supersock
Hired Gun!
Default z400
Finally.
LTZ 400 Service manual
It's a 47m file, so depending on your internet speed, it could take a while.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
