Checking LT50 Injector
Old Jan 28, 2009 | 08:07 PM
sportster04's Avatar
Default Checking LT50 Injector
Just picked up 1984 lt50 for my daughter and the previous owner mixed the fuel for it at 40:1. Said checking the oil was a pain so he did not use the oil injector. It seams to run a little rich so I want to use the injector. It has been 4 years since it was used. how do I make sure it oils right.
Old Jan 29, 2009 | 03:33 PM
DuneDragin's Avatar
Dune Rider
Which one of you is Pink?
we mix and don't use the injector. if it is adjusted to low, you'll burn up the motor.
check the plug for a light beige color after riding a short distance. don't let it idle when you come to a stop. If the plug is dark it is rich. If the plug is white it is to lean.
injectors are subject to failure...mixing is the surest way to keep this quad in
top running condition for years to come.
Old Jan 29, 2009 | 03:37 PM
DuneDragin's Avatar
Dune Rider
make sure you use a good grade synthetic oil.
(like Honda Pro 2 stroke synthetic...1 bottle to 4 gal of fuel)
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
