Front Sprocket
Old Feb 8, 2009 | 09:44 PM
lt230sman's Avatar
Default Front Sprocket
Well i was just thinking, would an extra tooth on a front sprocket help reduce the infamous c.c.o.s. on my 230?
i mean, im running 13-41 on it now, and its nice, i like it, and i dont plan on changing it, but just for the hell of it, does front sprocket size have any effect?
Old Feb 9, 2009 | 09:19 AM
JustRandy's Avatar
I think a larger sprocket would make it worse. Although I doubt 1 tooth is going to make THAT big of a difference when you're risking a $150 mag cover.
I kinda like the 11/37 combo myself. The idea is to keep the chain as short as possible. Less chain weight = more power to the ground. Also, since the front sprocket is smaller, the friction of the chain means less to the engine. That's especially important if you're running an o-ring chain!
I have a 14 tooth front. I hated it. You can order it thru http://www.jlatvproducts.com/ You might have to call them.
Old Feb 10, 2009 | 08:15 PM
mucky's Avatar
remember 1 tooth on the front equals 3 teeth on the rear
1 tooth larger on the front will reduce low end torque and give you more top end speed
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
