84 LT 125 , buring oil bad!
i got this bike used , and dont know the whole history about it ,
when i got it , it dont seem to smoke untill a changed the oil ,now it smoke really bad , it idle,and reving up, and decell, i mean it snokes bad.
he guy before said the just replace the rings, not sure if he did the head or not.
not sure ,if he really did rering it? of so he might have put the rings on upside down, or top ring or second ring or vise verser.
it does apper to have new gasket at the botton of the jug.
may he tore it down ,and didnt do nothing it it, them out it beck together to sell it ?
i mean it didnt smoke untill a replace the oil .????
do they make a smokeless oil?
im fouling the plug out in about 20 miles, first plug went 100 miles , second plug 50 miles . to 20 miles
do they make a anti oil fouler tip for these plugs? that screw in the head and the spark plug goes into it?
or what oil you think i should try ? its got 10/40 wt now
i think there called this . but i cant find them anywhere ?
thanks
Anti Fouling Spark Plug Extenders
thanks
where can i find these ?
anyone know the tread size of my suzuki 125cc.?
i dont know what car to look them up under , im looking for a temp qucik fix
http://www.autozone.com/images...ts/mtr/mtr42004003.jpg
4 stroke
4 my ref. only
SKU Item Price Qty Ext
64511-24201 SPROCKET, REAR (NT:49) $32.39 1 $32.39
27600-18910 CHAIN, DRIVE (428Vx90LE) $55.54 1 $55.54
27511-41701 SPROCKET, ENGINE (NT:13) $12.39 1 $12.39
61300-24821 TENSIONER SET, CHAIN (61300-24820) $54.19 1 $54.19
08120-62037 BEARING, FRONT HUB $9.79 4 $39.16
09284-22002 DUST SEAL, FRONT HUB $6.30 4 $25.20
14850-24500 TUBE, CLEAN OUT (14850-18900) $10.62 1 $10.62
09100-06011 BOLT $1.57 1 $1.57
Subtotal: $231.06
4 my ref. only
Subtotal: $231.06
to replace to timing chain do you have to pull the gear case apart?
itook this motor dowm ,the vavle guides are ok, and so is tha vavle seals. the bore dont look bad either , but the motor smoked very very bad?
anyone know what the head tq. is?
<div class="FTQUOTE"><begin quote>Originally posted by: Wrenchnalldatime
Good Luck You're looking up drivetrain stuff when u need engine stuff</end quote></div>
WTF? lol
anyways, reguarding your question of the timing chain, no you only need to take off the left side cover and the flywheel.
WTF? lol
oh wow aint that some **** hahaha! sorry my bad... i was thinking about a previous post where he listed a new piston, rings, etc in the same manner and i just figured that the list above was the same one haha.
