Wiseco Pistion
Old Feb 17, 2009 | 07:20 PM
lt230sman's Avatar
Default Wiseco Pistion
Well I FINALY got my +2MM LT250R cylinder back from la sleeve, and I noticed that the piston skirts are WAY thicker than my old ones. Any disadvantages?
Old Feb 18, 2009 | 08:06 PM
lt230sman's Avatar
anyone?
Old Feb 18, 2009 | 08:08 PM
theCATman's Avatar
Disadvantages??? Hardly. More durability & better heat dissipation.
Old Feb 18, 2009 | 08:20 PM
lt230sman's Avatar
better heat dissipation with the thicker walled one?
Old Feb 19, 2009 | 08:14 AM
JustRandy's Avatar
Better heat sink.
The only disadvantage I see is weight.
Old Feb 19, 2009 | 09:46 AM
LT80's Avatar
LT80 Expert
It's a good thing. [img]i/expressions/face-icon-small-smile.gif[/img]
Is it a Wiseco piston (says on box)?
Old Feb 19, 2009 | 05:52 PM
lt230sman's Avatar
yup, its a wiseco.
the new one is just alot thicker and heavier than my old one, so I was just wondering if i was going to run into any issues. (i guess it was a bad time to ask though since i just finished putting it in lmao)
Old Feb 20, 2009 | 09:25 PM
Doctorturbo's Avatar
GOT BOOST!
Life is a trade-off; and so are pistons.
Heavy is not good for several reasons.
#1 It will want to pull the rod in half at high RPM.
#2 It won't want to RPM as quickly.
It's always good to get as close to OEM weights unless the entire rotating assemble is balanced.
Old Feb 21, 2009 | 07:30 AM
theCATman's Avatar
It's probably a standard Wiseco. The last one was probably a Wiseco-Lite. So in all reality, this new piston is closer to original weight anyhow.
I wouldn't worry one bit about it. Just ride the quad!!!
Old Feb 23, 2009 | 08:29 AM
DR Q's Avatar
Piston weight is VERY important on a single cylinder ATV motor.
This affects balance/vibration/durability.
Try to keep to as close to the OE piston weight or a biy lighter if possible.
Q
STLyamwar
Jul 25, 2020 04:44 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Dabears1983
Jun 16, 2015 12:17 PM
TrailMix
Dec 5, 2000 11:50 PM
ronhonda
Oct 29, 2000 11:53 AM
