What 12" rims fit a 1994 suzuki LT-4WD 250 cc atv?
I have been looking into going to a bigger tire as most of you know, but have seen that I need to go to a 12" wheel/rim but I do not see any that fit because my atv is not listed in the application charts?
I guess I just need to measure the bolt pattern huh? or does anyone know what that is off the top of their heads?
thanks again
thanks again
http://www.mud-throwers.com/atv_wheel_chart The funny thing is they have the back oem tires listed as 24's. Doh!
Rockymountain has a 12x7 in the 4/140. Not sure if it would fit the front. http://www.rockymountainatv.co...yId=8633#vehicleSelect
yeah from the chart i found the front and the back are the same. and hey i guess it could be useful so i'll just go ahead and post it:
Suzuki LT Range ATV Tire Size / Bolt Pattern
.................................. ..............................OEM TIRE SIZE..........................OEM WHEEL SIZE,BOLT PATTERN
LT 50, 86-87 (F&R).............................. ........145/70-60................................. ..........................6x6, 3/90
LT 80 Quadsport, 87-05 (F)..........................19x7x8 ................................... .............................8x6, 3/120
LT 80 Quadsport, 87-05 (R)..........................19x7x8 ................................... ............................8x6, 3/120
LT/ALT 125, 83 (R)................................ ......22x11x8...................... ................................... .....8x8, 3/100
LT/ALT 125F, 84-87 (R)................................ 22x11x8............................ ..................................8 x8, 4/130
LT 160 Quadrunner, 89-02 (F)......................20x7x8.... ................................... .........................8x6, 4/112
LT 160 Quadrunner, 89-02 (R)......................22x10x8... ................................... ........................8x8, 4/112
LT 185 Quadrunner, 83 (R)...........................22x11 x8................................. .............................8x8, 4/130
LT/ALT 185, 84-87 (R)................................ ..22x11x8.......................... ................................... .8x8, 4/130
LT 230 GEG Quadrunner, 85-86 (R)...............22x11x8.......... ................................... .................8x8, 4/130
LT 230 GEF Quadrunner, 85-87 (R)................22x11x9......... ................................... ..................9x9, 4/130
LT 230 EH/EJ/EK Quadrunner, 87 (R).............22x11x9............ ................................... ...............9x9, 4/130
LT 230 EH/EJ/EK, 87-89, 91-93 (F).................21x7x10........ ................................... ...................10x5, 4/166
LT 230 EH/EJ/EK, 88-89, 91-93 (R)................22x11x9......... ................................... ....................9x9, 5/130
LT 230 QuadSport, 85-88 (F).........................21x7x10 ................................... ...........................10x5, 4/166
LT 230 QuadSport, 85-88 (R)........................22x11x9. ................................... ............................9x9, 4/130
LT 250 QuadSport, 89-90 (F).........................21x7x10 ................................... ...........................10x5, 4/166
LT 250 QuadSport, 89-90 (R)........................22x11x9. ................................... ............................9x9, 4/130
LT 250F Quadrunner, 89-02 (F).....................22x8x10.... ................................... ........................10x5, 4/140
LT 250F Quadrunner, 89-02 (R).....................24x11x10... ................................... .......................10x8, 4/140
LT 250E/F/G Quadrunner, 84-86 (R)...............22x11x9.......... ................................... ...................9x9, 4/130
LT 300 E Quadrunner, 87-90 (F).....................21x8x9..... ................................... ..........................9x6, 4/130
LT 300 EH Quadrunner, 87-88 (R)..................25x12x9....... ................................... .......................9x9, 4/130
LT 300 EJ Quadrunner, 89-90 (R)...................25x12x9...... ................................... ........................9x9, 5/130
LT 250R QuadRacer, 85-92 (F).......................21x7x10.. ................................... ...........................10x5, 4/166
LT 250R QuadRacer, 85-86 (R)......................22x11x10.. ................................... ..........................10x8, 4/130
LT 250R QuadRacer, 87-92 (R)......................22x10x10.. ................................... ..........................10x8, 5/130
LT 250 4WD, 88-02(F).............................. ....22x8x10........................ ................................... ......10x5, 4/140
LT 250 4WD, 88-02 (R)................................ 24x11x10........................... ................................... ..10x8, 4/140
Z250 2WD, 02-08 (F)................................ ...22x7x10......................... ................................... ......10x5, 4/144
Z250 2WD, 02-08 (R)................................ ...20x10x9......................... ................................... ......9x9, 4/110
Tire Example:
25 x 10 x 12
Tire Diameter = 25"
Tire Width = 10"
Rim Diameter = 12"
Wheel Example:
10 x 8 3+5 4/110
Wheel Diameter = 10"
Wheel Width = 8"
Wheel Offset = 3" mounting centerline to inside wheel edge and 5" mounting center line to the outside wheel edge
Number of Bolt Holes = 4
Spacing of Bolt Holes = 110" (measured from center of one bolt hole across center of wheel to opposite bolt hole)
Note: Most OEM Wheel Applications have no offset (the wheel is centered over the hub). In these cases, the wheel offset is omitted from the listing.
Tire Example:
25 x 10 x 12
Tire Diameter = 25"
Tire Width = 10"
Rim Diameter = 12"
Wheel Example:
10 x 8 3+5 4/110
Wheel Width = 8"
thanks , I see that the rear does show a 24 and not the 25 that is on the bike
I think I will go with a 23 x 7 10 for the front if the chart calls for 24 rear and 22 front well I have 25 on rear will just go to a 23 in the front keep it simple.
thanks again
thanks again
Sep 1, 2015 11:59 PM
