when do i need my valves adjusted???
Old Mar 10, 2009 | 07:07 PM
Phil05Eiger4x4's Avatar
Default when do i need my valves adjusted???
what issues will you have when the valves are out of whack??????i got 1862 miles on the eiger ..can it cause the quad to run fine until like climbing and the power just isnt there?
Old Mar 12, 2009 | 11:59 AM
NewportHillClimber's Avatar
itll lack power because your compression will start to fade. but at a point it will crank and run till it gets warm then it will die
Old Mar 14, 2009 | 04:23 PM
check for an air leak or if your breather needs recharged
Old Mar 14, 2009 | 04:24 PM
or even a loose intake. either way it sounds like its running lean
Old Mar 14, 2009 | 07:36 PM
GrnXnham's Avatar
With valves look for backfiring and hard starts.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
