eiger automatic CVT drain?
Old Mar 29, 2009 | 04:09 PM
Dallas700's Avatar
Default eiger automatic CVT drain?
My son drove his eiger in some deep water and it made a funny noise and died. It started back up and ran funny for a mile or two but then ran fine after. Is there a way to check to see if he got water in the CVT? I see a metal drain plug but no clear plastic check point. I bought it used so I do not have the manual and have not bought a clymer yet. If he did get some water in the CVT belt area what would you recommend?
Old Mar 29, 2009 | 08:00 PM
tydogg's Avatar
There is a small bolt on the bottom of the belt housing to pull out.
Old Mar 29, 2009 | 08:49 PM
Dallas700's Avatar
If he did get water in the belt housing is there anything special I should do other than drain the housing?
Old Mar 29, 2009 | 08:53 PM
tydogg's Avatar
I don't think you should have to unless you have a oil seal leaking also.
Old Mar 29, 2009 | 09:15 PM
Stainless's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Dallas700
If he did get water in the belt housing is there anything special I should do other than drain the housing?</end quote></div>
Nea just drain it. Happens all the time. As far as it running weird.. was it slipping or having problems changing gears? If it was the engine that was acting weird it could have sucked water into the airbox.
Old Mar 30, 2009 | 09:52 AM
rolsmojave3's Avatar
Did water get into the airbox?
Old Mar 31, 2009 | 09:39 PM
Dallas700's Avatar
There was no water in he air box, he backed down in a pond and I think the water got in the snorkle for the CVT. It's the one that's located right under the rear plastic by the battery box.
ReconBayou
Oct 31, 2022 05:37 PM
Alex G.
Sep 11, 2017 11:38 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
