06 z400 chain problems help please!!
Old Apr 17, 2009 | 07:42 PM
brink2188's Avatar
Default 06 z400 chain problems help please!!
got an 06 z400 and the chain started jumping on the rear sprocket and i looked and the front sprocket was missing teeth so i changed it and now when i ride it it pops real loud and some times squeaks loud i have also noticed that when its not running and i pull it by hand backwards the chain gets really tight and i can barely pull it i was wondering if any one knew a solution to this problem it would be greatly appricated thanks
Old Apr 17, 2009 | 09:01 PM
lt230sman's Avatar
well, chains tend not to stretch completely evenly, so chances are thats why it goes tight to lose, and vice versa.
your best bet would be to get an new ORING chain (RK520SRO5 is great, cheep stuff) and rear sprocket. you should never put a new chain on worn sprockets, so you might wanna replace the front again, especially if its been under strenuous conditions like the varying tension.
while youre at it, check you carrier, output shaft, and swingarm bearings.
good luck!
Old Apr 17, 2009 | 09:03 PM
lt230sman's Avatar
just make sure you stay away from the non o-ring ****!!!!!
absoloutley WORTHLESS!
they stretch like rubber bands and dont track as straight as thier beefier, sealed counterparts.
Old Apr 17, 2009 | 09:37 PM
brink2188's Avatar
thanks for the advice i just bought the quad and the guy said that he had just put a new chain on right before i bought it could not changeing the sprockets also be why this is doing this to me id say the chain has under an hour of ride time on it also i noticed that i can move the front sprocket back and forth after ive got it all tightened down is this normal again thanks
Old Apr 17, 2009 | 09:38 PM
brink2188's Avatar
thanks for the advice man
Firefighter400
Oct 8, 2022 06:38 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Jul 15, 2015 02:07 AM
