do i have to break in again
Old Jun 25, 2009 | 10:34 PM
91Warrior357's Avatar
Originally Posted by lt230sman
BAD BAD BAD!!!
you should NEVER keep a fresh engine at ANY constant speed, fresh rings need varying crankcase pressure/vacuum (only attainable by rpm modulation) to seat properly.
lol im talking about this for a 2 stroke and RIGHT after start up for the first time, i dont have it like this very long, no its not bad alot of my buddys who race motocross do this same thing, take there bike from the shop brand new rebuilt and say its a 1 hr ride the fire it up set the idle a little high then take off down the road and then the race it full speed, ive also seen alot of people on blasters do this method also, some people have some vids on youtube doing this, i knew this topic would bring in alot people trying to argue this, have at it.
Old Jun 27, 2009 | 10:53 PM
Bansheerider252's Avatar
Smile Reply
the repair shop who fixed my z400 the man told me to just ride it easy for the first two or three rides then i can dig in here but i that don't sound right to me shouldn't i change the oil and filter or just the oil.
Old Jun 27, 2009 | 11:28 PM
scrambler400enoge's Avatar
Shapeshifter Rider
BAD BAD BAD!!!
Especialy 450's which have those little slipper pistons that tolerate alot of Compression blow by, after which dilutes your oil. Which is why frequent oil changes and valve adjustments are needed to keep your 450 in top shape.
Old Jun 27, 2009 | 11:29 PM
Shapeshifter Rider
I would follow the link that was posted earlier. That guy has alot of credibility. After the break in clean the filter and change the oil.
Old Jun 28, 2009 | 08:07 AM
  #15
Stoopidbot's Avatar
X2 On a fresh rebuild there is a possibility of fine metal shavings circulating around. It is very important that you change the oil and filter during the break in. I recommend about 2 in the first 10 hours, a third in the next 10 hours. That will ensure that if there are any shavings left from the rebuild, they will be washed out.
Old Jun 28, 2009 | 05:24 PM
  #16
mudslinginfool's Avatar
Does it in the Mud!
Ive seen it done both ways. I took it easy on my 2002 500 for the 1st 100 miles(10hrs) and the bike has almost 4,000 miles on it now and its never had an issue,still runs strong. My friends have unloaded their bikes and ran them hard from day one and they still run strong. Engines are designed totally different these days. everything is more precise fit. I say run it how ever you want because i have never heard of someone blowing their engine up because they didnt break it in right. Ive heard them blow them up because of neglect, they would run them with not enough oil,or run them full throttle for 20 minutes in 2ft of mud,ect...Either way,just make sure the oil and filter gets changed on a regular basis and it will last a very long time. good luck
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
atvcollector
Sep 8, 2015 05:11 PM
