1992 Suzuki LT 250 Neutral Problem. HELP Please!!!
I have a 1992 Suzuki LT 250 Quadrunner. I put about 20 miles on it the other day and it ran great. I parked the 4 wheeler for about an hour while it was raining. After the rain stopped I went to start the atv and noticed that I had no neutral indicator light. I made sure I was in neutral but the light never came on. Well, since the neutral light will not come on my electric start will not work as well. Every other light works on the atv including reverse. I am able to pull start the atv with no problem. I check every wire that i know possible. I tried a new neutral start relay and that was not the problem. I checked every fuse and that was not the problem. Does anyone have a clue? Thanks.
If not then it's probably your reverse switch.
09-01-2015 11:59 PM
