Quadrunner carb ?
Old Oct 19, 2009 | 01:50 PM
akarotten's Avatar
Default Quadrunner carb ?
94 quadrunner ltf250 ,Engine runs well no problems running out thru the gears but idles slow,stalls when ideling just sounds to slow of an idle to me so i look in manuel and it says to adjust idle scew to certian rpm,s [forget what it was at the moment ,manuel not here with me] and shows screw near top of carb,so i get screwdriver ,pull off seat a low and behold no screw where the show one,looks to be a place where screw shows but sealed up,any ideas.As i said engine runs great otherwise.Thanks in advance
Old Oct 19, 2009 | 06:55 PM
Sisco1957's Avatar
On a Suzuki the idle adjustment is on the right side. The screw is on a cable that comes from the left side of the carb and runs under and to the right side. It will have a black **** on it. Hope this helps.
Old Oct 20, 2009 | 12:34 PM
akarotten's Avatar
Thanks a lot for the info sir!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
bikedad3
Jul 2, 2015 02:15 AM
