Vinson trouble
Old Nov 8, 2009 | 11:58 AM
emtmike's Avatar
Default Vinson trouble
I have a 2002 Vinson 500 auto. I don't use it much, mostly just for plowing in the winter. I am having problems with it and was wondering if I could get some help from you pros. It's hard to start. When it does run there is a hose that comes from the top of the carb and ends up under the seat that gas runs out of when its running. It will not idle without the throttle. If I shut it off, or stalls, the gas keeps coming out of the hose. I have to shut the gas off at the tank to get it to stop. There is also gas in the air filter box. Any ideas?
Old Nov 8, 2009 | 12:33 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Any chance that you are running it with the fuel valve set on prime? The '02 Vinson does not have a fuel valve 'OFF' position, only run, reserve and prime. If you leave it in the prime position, it will leak fuel and/or dump it into the airbox.
Old Nov 8, 2009 | 02:14 PM
emtmike's Avatar
I have tried it in all 3 possitions and it will ether stall out or keep pissing gas out of the hose
Old Nov 8, 2009 | 04:15 PM
Sounds like time for a carb. cleaning. Stuck float or needle valve?
Old Nov 15, 2009 | 12:07 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
stuck float. Get a new float kit at the dealership (or online) and see if it still leaks after you install it
Old Nov 22, 2009 | 12:49 PM
emtmike's Avatar
OK I took the carb all apart and cleaned every nook and cranny. Well I took the diaphragm cover and took the spring and jet needle and the other thing that looks like a crown, not sure what its called, out and shot carb cleaner all through it. I took all the other covers off and did the same. I put it all back together and put it in the bake and there is still gas pouring out of the hose that comes out under the seat and gas running into the filter. What the heck is wrong?
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
