LT230H neutral light
The neutral switch does not work. I looked on parts sites and they don't make it. The starter will no run if the light is not lit? Is there a way to put a manual switch inline to the neutral/reverse switch in the block? I have the switch out and the reverse works, but neutral doesn't. I was giving this atv to my grandson for Christmas and need to get it started. Any help will be appreciated. I have been unable to locate a wiring schematic for the neutral/reverse switch. It looks to be a normally closed switch to ground for reverse and depressed is supposed to light neutral light. There are 4 wires going into switch housing. However, the plugs out only have 3 wires.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
