Help with 1997 king quad 300
Old Dec 30, 2009 | 07:31 PM
EX80's Avatar
Default Help with 1997 king quad 300
I bought this quad to plow my drive way. Problem i have is, i think it only runs on choke. Choke is the down position with the arrown facing down, correct? I pull up the lever the quad just dies. I changed the choke cable and the plastic choke screw where the calbe goes in. I also took apart the carb and cleaned everything. Is there something i am over looking?
Old Dec 31, 2009 | 06:28 AM
boomerdog's Avatar
Didi you soak the carb overnight in carb cleaner then blow out every single passage? After that did you readjust the idle and air mixture screws?
Old Dec 31, 2009 | 08:26 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
BTW, you are correct in that the choke is on when it is in the down position.
Ashley S
May 29, 2017 10:54 AM
robert301972robert
Aug 30, 2015 11:34 AM
Peter_
Jul 18, 2015 07:06 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
