'04 Arctic Cat W/ Suzuki engine won't start
Old Feb 3, 2010 | 02:20 PM
kennedy4597's Avatar
Default '04 Arctic Cat W/ Suzuki engine won't start
I have a '04 Arctic Cat 500 auto 4x4 (Suzuki engine with about 400 miles and 80 or so hours) that will not start...I replaced the plug a few months ago and it is clean...I can get to it run with a squirt of starter fluid directly into the carb, but it runs for about 10-15 seconds and then stalls (I've done this about 3 times)...I don't want to continue to use starter fluid, and have something go wrong in the cylinder from that...it does sit for periods of time....any suggestions? THANKS!!
Old Feb 3, 2010 | 05:32 PM
HeftyLefty's Avatar
The carburetor is stopped up. Remove, disassemble, and clean thoroughly with carb cleaner. You will probably have to replace the jets, dealer should have a kit.
Old Feb 3, 2010 | 08:21 PM
how difficult of a DIY project would this be....I have a shop manual
Thanks for the reply
Old Feb 4, 2010 | 10:59 PM
HeftyLefty's Avatar
Not hard at all. Get organized before you start. Cover your worktable with a high visibility cover, so you can see dropped small parts. Buy plastic drinking cups and a felt marker to store the screws in, and the order you removed them. Write down on note pad.
Have good lighting, be VERY patient, and save the beer till finished.
Old Feb 16, 2010 | 02:27 PM
ericvinson's Avatar
i would put some fuel injector and card cleaner in it from time to time
Old Feb 16, 2010 | 04:15 PM
Jack_Bauer's Avatar
does your bike have the automatic choke? if so, there's an over ride lever by the carb you can use to prime
Old Feb 16, 2010 | 04:47 PM
tommyis3's Avatar
Also, dont put any rubber parts in the carb cleaner, they will be twice the size when you put your carb back together.
neilbedwell
Nov 10, 2018 11:02 AM
chinkapin
Jul 14, 2016 06:58 AM
alix
Jun 28, 2015 03:28 AM
kevbowe
Jun 1, 2015 01:17 AM
1000gade
May 27, 2015 12:37 PM
