lt 50
Old Feb 6, 2010 | 12:05 AM
JEREMYZDEAD's Avatar
Default lt 50
The mix screw is a 1/4 turn out and the idle screw is almost all the way in. it runs fine like that. I know its not supposed to be like that. Help please.
Old Feb 6, 2010 | 09:02 AM
LT80's Avatar
LT80 Expert
Clean the carb. Maybe the pilot jet is plugged.
Do a compression check if it's not the carb.
Old Feb 6, 2010 | 02:41 PM
I took the carb apart and the screw was all the way into the slide. So I JB Welded it. Put it back together, not before taking the top pilot jet out. I also drilled holes in the air box cap. I think the other restrictors are already out. I put it back together and it runs fine.
