Suzuki LT230S with Ninja 500 2cyl engine
Old Mar 3, 2010 | 11:44 PM
  #21
kawazuki500's Avatar
Originally Posted by lt230sman
are you having problems with the rear brake? because the one in your pic isnt original....
Yes. I need the original rear caliper. Not sure why they changed it to the one that is on there now, but when you put the pads on this one, the pads that are meant for the original 230S caliper, the pad on the piston side falls out. I suppose it would work fine if it had the right pads for this caliper, but no idea what this caliper came from.
Bike is a 1985 LT230S, so I guess it's really really old...
Another question, about the ball joints, the lower ball joints on this bike seem to have a bolt that goes through the backside of the A-Arm and into the ball joint to hold it... at least that's what it looks like, I haven't tried to take it apart to be sure... I seen ball joints on Ebay for the LT 230S but they had snap rings with them and didn't appear to have a bolt hole in them so now I am confused if these are the original A-Arms or not...
Old Mar 4, 2010 | 07:23 AM
  #22
Trailrider230s's Avatar
I have an extra rear caliper for a 230s. if youre interested. its off a 1985 lt230s.
Old Mar 4, 2010 | 07:30 AM
  #23
Oh and those are the original a-arms. both of the ball joints should bolt on. 3 bolts for the top ball joint and 1 really big bolt on the bottom one. and it is a pain to get out. the bottom bolt is almost always siezed, so keep a cheater bar with ya when you go to remove the lower ball joint.
Old Mar 4, 2010 | 09:55 AM
  #24
Thanks for the info. PM me price on the caliper. Shipping is to 77484.
Old Mar 4, 2010 | 09:56 AM
  #25
Best place to get new Ball Joints for this Bike? All four of them need replacing....
Old Mar 4, 2010 | 12:05 PM
  #26
probly ebay, All ***** makes a good ball joint. I'll get the links and post them up in a sec.
Old Mar 4, 2010 | 12:08 PM
  #27
Here they are:
Suzuki LT230S Quad Sport Upper Ball Joint 85-88 LT230 : eBay Motors (item 370334857256 end time Mar-14-10 17:51:05 PDT)
Suzuki LT230S Lower Ball Joint 85-88 LT230 Quad Sport : eBay Motors (item 350118581672 end time Mar-24-10 20:10:37 PDT)
Both of these will work and they last forever. at least for me they do. I ride every day for hours. tons of useage on my 230s.
Old Mar 4, 2010 | 01:32 PM
  #28
Originally Posted by Trailrider230s
So it's basically $200 to replace all four front ball joints but these All ***** joints are really good and last forever? Sounds like a good deal, seems like quite an expense at first, but I guess it will beat breaking down and wrecking the bike because a ball joint came apart...
Old Mar 4, 2010 | 03:06 PM
  #29
Thanks for the deal on the brake parts.
Hopefully I can work on the bike some soon, like next couple days or next week. Will take some new pics and post them here.
Old Mar 4, 2010 | 11:07 PM
  #30
86qscamo's Avatar
im pretty sure if a ball joint cut loose on you with that bike it would probably be a widow maker , how much power does that engine make any way and how much modification is needed to make it fit , i love my quad but its for sure underpowered, those motors seem to be a bit cheaper than a gsxr600, and that was my plan for a while any info would be great
