For those that have done compression tests...
Old Mar 3, 2001 | 10:29 AM
2000MOJAVE's Avatar
Old Mar 3, 2001 | 12:18 PM
minehunter's Avatar
First off by using your own figures and converting your one cubic foot of air. If you changed it to 1 PSI and compressed it 13.27 times what would your air pressure be now? It should be 13.27 PSI, but it won't. Now I'll admit my mistake. I forgot to add into the formula the heat generated by compression. Along with heat, comes an increase in the moleular activity of the subtance being heated. When a gas is heated the pressure increases, therefore you can have pressures higher than just the mathmatical formula states. I stand corrected.
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
