Odd size tyre on quadrunner
Old May 9, 2010 | 01:36 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Originally Posted by Kenm
So, the front tires and the rear tires are the same circumference, and the front tires are rotating faster than the rear tires. It seems to me that they would scrub any time you were in 4WD. What am I missing?
You're not missing anything, that's exactly what happens. However, the difference is so small that unless you are on a hard pack surface you don't notice it.
I always kept my KQ tires at OEM size for the front and rear, but I rode with several other KQ owners who had switched to the same tire size front and rear. They never had any problems with scrubbing.
Old May 9, 2010 | 11:16 PM
Kenm's Avatar
Ok, I checked the KQ 300 specs. It has a 25 inch tire in the rear, and and a 24 inch tire in the front. This comes out to a 4% difference. Not something I would do, but I see what you are saying.
The difference in the circumference of the Quadrunner tires rear to front is 14%. In other words, for every 600 feet you drive in 4WD the front tire will have to "scrub" 14 revolutions.
Old May 9, 2010 | 11:32 PM
Kenm's Avatar
Originally Posted by mozzer
Thanks very much for the replies.
Found the VIN now, cheers Kenm.
It comes back as a 1987, I'm hoping the CLymer book will tell me what I need to know from there.
It has 2wd, 4wd and diff lock so if the diff lock is off but it is in 4wd I suppose a slight difference in front to rear gearing is OK, assuming the transfer case is an open type diff and not a viscous clutch type design.
I'll get the tubes fitted and go play.
Next will be the driveshafts (three out of 4 cv boots are split and the rear shafts are sloppy where they go into the diff) bit one step at a time.
You're welcome mozzer,
The diff lock is to lock the front differential so that both front wheels spin at the same speed, not to lock the front and rear differentials. Obviously there is no rear diff as the drive shafts come straight out from the engine case. This is a great feature, it saves weight, maintenance, and mechanical losses. There is no transfer case or center differential like you would see with a truck or a Subaru or Honda CRV.
I've never messed with CV joints but I know that a bad boot is the kiss of death for them.
How many KM on your new toy? And, lets see a picture!
Old May 12, 2010 | 12:23 AM
mozzer's Avatar
Thanks for the 4wd lesson.
I think the CVs are probably shot, 3 of the boots are split but I'll try pulling the shafts and see how the joints feel.
It has 13,000 kms, has aluminum back end, a cheap winch.
Old Mar 15, 2011 | 07:01 PM
  #15
convicted21's Avatar
Im trying to find some new tires for a 98 Quadrunner, where is a good site with tires this size?
Old Mar 15, 2011 | 07:29 PM
  #16
Trailrider230s's Avatar
rockymountain.com or motosport.com is good. all orders over $100 you get free shipping.
Dammar
Apr 20, 2016 06:03 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
phummer3210
Sep 11, 2015 03:47 PM
