LTZ400 Questions- Carb, etc
Old May 15, 2010 | 09:57 PM
scrappy312's Avatar
Default LTZ400 Questions- Carb, etc
I got an 04 LTZ400 that I bought in pieces. I have a manual, and I got the thing pretty much back together, but the manual doesn't really indicate where the hoses on carb go. I hooked them up in what I thought were their logical locations (vacuum to the petcock, and the large inlet on the carb to the large outlet on the petcock), but this carb seems to be dumping fuel straight into the cylinder. Any ideas?
Old May 16, 2010 | 01:11 PM
cataway's Avatar
i suspect the needle for the float has a speck of dirt holding it open or the float needs to be reset
Old May 16, 2010 | 02:13 PM
scrappy312's Avatar
I think I have bigger problems right now. I was about to tear back into the carb, and I decided to pull the plug and see if I had any compression, and although I don't have a compression guage, it feels very weak just putting my finger over it. I checked the ring end gap when putting it back together with new rings and honed cylinder, but I guess I'll pull it back apart and check to make sure I didn't funk anything up
Old May 18, 2010 | 07:53 PM
bduncan's Avatar
I have a 1994 Suzuki king quad 300. I am having the same problem. I need to know where in the worl the hoses hook up from the carb to where ever they go. Please help, any help will be greatly appreciated!!!!!!!!!!!!!
Old May 18, 2010 | 09:44 PM
scrappy312's Avatar
how many hoses you got coming off the carb? Is the fuel petcock vacuum operated? If you post a pic, we can probably figure it out
Old May 19, 2010 | 03:22 PM
bduncan's Avatar
Default carb problem
Hey. They are a total of 5 lines going and coming from the carb. I do believe that the petcock is vaccum operated because there are two lines going to the petcock. The line coming from the petcock goes to this what I am assuming is a fuel pump. I took it apart and all it had was a diaphram with a spring in it. Then one line goes to where the main fuel ine goes to the carb and there is another line where I am not sure where it goes that is on the bottom of the fuel pump. I applied a link that will show you a picutre of my carb that is on the four wheeler. Later on tonight i will acutally take pictures of the carb and assuming fuel pump so we can get a better look at it. Thanks in advanced.
Fiche Parts
Old May 20, 2010 | 08:56 PM
2strokezilla's Avatar
boy am I glad I took that vacuum carb off my sons Z400 all that works great when its working but when it doesnt what a headache! Also you honed the cylinder? I thought it was a plated cylinder wall didnt think you could hone it
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
