i took the top end of my lt230 apart and need cam help
Old May 23, 2010 | 05:43 PM
himsa169's Avatar
Default i took the top end of my lt230 apart and need cam help
I was all anxious to pull my motor apart and took the head and jug off (the whole top end apart) so i took the cam chain off the sprocket and i forgot to make a mark were the chain was so the cam opens the exhaust and intake valves at the correct time what is a good technique to figure out exactly were the cahin goes on the sprocket there are two markings but not sure which to use etc please help thanks
Old May 23, 2010 | 07:21 PM
NewportHillClimber's Avatar
put crank on TDC and position cam to where the two dashes on end are parallel with top of head. you can tell if its correct because the two lobes of the cam will be at 5 and 7 o'clock positions
Old May 23, 2010 | 10:01 PM
himsa169's Avatar
Default whats the best way to clean a exhaust valve
thanks man and i took my head off and the exhaust was filled with carbon is wire brushing it a good idea i sprayed it really good with carb cleaner(i will have it apart for a while so plenty of time to dry) but it is still blak and there are chunks of carbon
Old May 23, 2010 | 10:16 PM
lt230sman's Avatar
wire brushing is fine but if you use a wire wheel be sure not to scuff up the sealing surfaces too much (aluminum is softer than you think!). and newport's right on with the timing procedure. and another indicator is that with the score marks in the cam level with the top of the head and the crank at TDC with both lobes DOWN, the pin that goes in between the cam sprocket and cam should be at around 11 o clock.
good luck!
lonerider856
Oct 13, 2023 03:45 PM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
230Srider
Jul 17, 2003 06:30 PM
QuadDude05
Jan 3, 2001 01:35 AM
