inner tube sizing
Old Jun 13, 2010 | 10:13 AM
mozzer's Avatar
Default inner tube sizing
Does anyone know how inner tubes are sized. I have 25x13.5x10 rear tyres and need tubes but cannot see what size I need
Do the sizes relate to the average width or diameter.
Old Jun 13, 2010 | 11:19 AM
NewportHillClimber's Avatar
they are sized specifically for each tire. but one tube usually does about four or five sizes of tire. but if you put tubes in the tires and get on it good you will tear the valve stems and have a flat. so you may wanna just save your pennies and get some more tires.
Old Jun 13, 2010 | 11:52 AM
mozzer's Avatar
Yes I'll be changing rims and tyres once I've worn the rubber out.I'll look up an equivalent tyre in 12 inch rims or whatever fits and is more common.
The exisitng rims have some pinholes in them and the tyre shop says they are designed for tubes although tubeless tyres are fitted.
I think he ordered a 22 inch tube, I'm assuming this is less important than the rim diameter
ReconBayou
Oct 31, 2022 05:37 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
CosmoM
Sep 21, 2015 04:57 PM
