quadzilla help
Old Jul 26, 2010 | 09:49 AM
madzilla's Avatar
Default quadzilla help
i need help setting my needle jet for 2100 ft. elevation and i have water leaking out of a hole thats under the water pump in the case cant tell if its threaded for a plug ? this is my first zilla
Old Sep 30, 2010 | 03:13 PM
willard13's Avatar
Default waterpump
i cant help you on your elev., but on your waterpump the nut underneath it is to drain the radaitor. if it is leaking from there, you can just replace bolt which is metric or use some plummers tape or some sealent. any other question let me now. i just redone a 85 lt250r, from the ground up.
Old Oct 1, 2010 | 09:29 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Thats the weep hole that lets you Know the water pump seal is bad.
Ashley S
Feb 18, 2024 08:56 PM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ashley S
Aug 6, 2015 12:56 PM
FENDERBENDER
Mar 12, 2000 01:04 PM
