Suzuki Wont start
Old Aug 8, 2010 | 07:00 PM
Daverdawg's Avatar
Default Suzuki Wont start
Yes i have a suzuki 1990 LT4WD. When i try to start it in neutral nothing happens at all and the neutral indicator light does not come on either. However when i put it in reverse the reverse indicator light comes on tho. It does nothing when i try to start it, as if there isnt a battery in it. Would it be the neutral relay or neutral switch? Any help here would be deeply appreciated and thanx.
Old Aug 24, 2010 | 12:57 AM
mgshilling's Avatar
I have the same problem but I am at least able to pull start the engine. Once it's warmed up I can use the electric start switch as normal (nuetral light is on now). Saw one post they said to clean the fuse box out (they had mud and other such trail souvenirs caked in it). I can only hope it's that easy of a fix.
my real concern is that this started around the same time I overheated the engine plowing my drive last winter.
what should I be looking foras possible repairs if this is the case?
neilbedwell
Nov 10, 2018 11:02 AM
Wromberger2016
Jun 22, 2015 02:07 PM
Jun 3, 2015 01:40 PM
1000gade
May 27, 2015 12:37 PM
ragewraps
May 26, 2015 03:14 PM
