how to clean inside of Muffler pipes?
Old Aug 23, 2010 | 02:19 AM
Scottie_The_Boy's Avatar
Question how to clean inside of Muffler pipes?
How do ya's go about cleaning the Old Oil and such biuld up inside pipe/header pipe when you are doin' a ring and valve job, and want to make sure it isn't oil from in the pipe thats making it smoke ?
Some told me to use gas and soak the pipe in it and some said to use Kerosen... I felt Gas may work best and just allow it to hang for days to vent out the fumes and vapors.....and then use a cordless drill and a long 1/8th cable with a shotgun wire brass brush on the end so I could clean off loose peices and such...
Any Tips on how you would go about it, Or do ya's just install the pipes and figure you have the ring and valve oil burning licked and the pipes just have to have run time to burn off History added up oil and such in um'?
Is there away to repack Or Biuld the Muffler end of the Pipe on a lt230 machine?
Thanks
Scottie_The_Boy
Old Aug 23, 2010 | 10:44 AM
chris111179's Avatar
I just use a presure washer too wash all of the junk off of it but be-careful! That stuff goes everywhere. i have cleaned a pipe on a 25+ year old wheeler it was caked with black crap and when i was dont with it i cleaned my gogles off! and the pipe was down to bear metal. and it looked amazing. thanks for reading this
Old Aug 23, 2010 | 12:18 PM
SeanBean's Avatar
I DO NOT recommend you do this because it can cause bodily harm and more damage. Dont do it. When I saw this, i thought of what my uncle used to tell me when they would heat the pipe red hot with a torch, then run it. It would cause a pipe fire and burn all the stuff out. Of course if you had muffler packing, it would be destroyed. And probably burn down the shop. But hey, this was 30 years ago.
Again, I only posted that as a funny story, and not a suggestion on what to do. DONT DO IT!
Old Aug 23, 2010 | 12:29 PM
scootergptx's Avatar
Supersock
Hired Gun!
Gotta go along with this post.
Gas? You have any left in the pipe and one backfire...
Old Aug 24, 2010 | 06:50 AM
Cool
when you get the pipe red hot it does nothing all it does is waste propane, pressure washing is the best way to to it all you have to do is take the exhaust befor you start...... and bodily harm come on if you use common scene you will be fine
Old Aug 24, 2010 | 08:07 AM
LT80's Avatar
LT80 Expert
I stick pipes in my wood stove or in charcoal to get red hot. I then blow comressed air thru it.
CAREFUL!! Like mentioned, it'll throw flames.
DON"T USE GAS.
Old Aug 24, 2010 | 10:04 AM
SeanBean's Avatar
When you get it red hot, all the carbon buildup on the inside of the pipe comes off. It will of course burn and cause fire on the way out. LT80 had a bit of a safer way of doing it I think, you know, cuz then its not attached to the bike hahaha.
slowgsxr97
Mar 18, 2022 03:40 AM
greg74
Sep 10, 2019 03:03 PM
zach1106
Jul 31, 2015 01:55 AM
traumajunkie
Jul 23, 2015 02:10 AM
Reactant
Jul 16, 2015 10:29 PM
