94.quadrunner carb ?
Old Sep 5, 2010 | 11:46 AM
akarotten's Avatar
Default 94.quadrunner carb ?
Ok i,m gonna ask again,Anyboby tell me whats involved in taking carb off a 94 quadrunner 250?Isee carb but it looks rather involve in gettin it off,i want to rebuild and put new carb kit in.Just not sure how to get at it to remove,plastic removal or get it from seat?also on the top of carb is a round plunger cap,does it unscrew or just pull off.Thanks.
Old Sep 5, 2010 | 04:22 PM
akarotten's Avatar
anyone!
Old Sep 17, 2010 | 02:09 PM
akarotten's Avatar
Talking
surley someone knows?
Old Sep 17, 2010 | 04:00 PM
Sand Hog's Avatar
Remove all of the plastic first don't think you can take it from the side without removing every piece of the plastic coverings from the sides and top of the quad. Through the top you got to go through the air box and fuel tank first so your still going to need to remove all the outer plastic.
My Advice..Get a shop repair manual first before you attempt to do the work it will save you tons of heart ache in the long run and maybe save you from breaking a very small and very expensive impossible to find part as you try to remove it.
Old Sep 17, 2010 | 06:00 PM
TLC's Avatar
TLC
This link is for a sled but it tells you how to remove and clean a Mikuni Round slide Carburetor which is what you have. Disassembly and Cleaning of a Mikuni Round slide Carburetor
Old Sep 20, 2010 | 08:58 PM
Sisco1957's Avatar
You can remove the carb through the top without removing any plastic. Back off the clamps to remove the carb and rubber tube between carb and air filter box at the same time. Putting this hose back in place will be the hardest part. The top has 4 screws holding it on.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
