Suzuki Ozark 250
Hello there i have an 07 Suzuki Ozark 250 and i've been riding it pretty hard for the past 3 years i've owned it. I took it up to a guy who runs a repair shop and he brought to my attention that three wires had come unplugged in the back that apparently run between the battery and the regulator or stater or something like that. He told me he didnt know where to plug them back into and if he did it wrong that it could ruin the regulator and that service manuals dont show the order they're supposed to be plugged in. I was wondering if anyone had an 07 Ozark that they could take a look at and possibly show a picture of the wires for me.
I dont want to drag this out too long but there are 3 solid black wires, 1 red wire, and 1 black with a white stripe. The red wire is plugged in still, and a black plugged in below it, but the other three are unplugged. Basically i just need to know where the black wire with a white stripe goes, because there is only 3 holes open so whichever are left would take them. Thank you in advance
Welcome to the forums.
Does the machine run right? Does it charge the battery?
If nothing is wrong and there is no obvious place for the wires, I'd presume all is well and that connection may be for something else.
Maybe look at a parts fiche.
Does the machine run well? Does it charge the battery?
If so, I'd presume all is well.
Look at the parts fiche. It shows the harness like it's on a frame with the connections and such.
Click on this::
Motorsports Super Center | Can-Am (Bombardier) OEM Parts | Polaris OEM Parts | Sea-Doo OEM Parts | Suzuki OEM Parts | Yamaha OEM Parts
Click on this::
Well its running fine, other than being worked on right now to replace the brakes, but the loose wires run from the battery and they recharge it while its running.(or are supposed to at least)
Right now since they're not connected the battery isnt receiving a charge while it running. Its a week old battery so its holding up fine so far but without charging itself its bound to give out sometime soon.
EDIT
I looked at the site you linked and shows the assembly of the wiring harness but the wires are attached to a piece that plugs all of them into the same spot. Unfortunately the wires are unplugged from that piece and aren't supposed to be. It does not show which order the wires should be attached.
EDIT
Sep 1, 2015 11:59 PM
